wpslo314
Feb 26, 2017Guide
rn314 will not see an 512gb sdxc card.
The display shows that the card has been plugged in but neither WIndows Explorer nor the RAIDar show that the card is present. I am using a Samsung adapter which works fine on PCs. Does anyone have...
- Mar 01, 2017
Thank you StephenB.
I have taken up your suggestion and made the ideas post.
The other NAS is a QNAP_TS253pro.
It is surprising that such a common file structure is not supported.
wpslo314
Mar 01, 2017Guide
RN31400 Hi, The GUI on the front of the RN314 displays "External Storage Device Connected" when the USB to SD Card adapter [ which has an SD Card inserted ] is plugged in.
Mar 01, 2017Guru - Experienced User
Do you know the file system format on the card?
- wpsloMar 01, 2017AspirantHello, The file structure is "exFAT" . Regards, wpslo. PS The SDXC card is read by a NAS not of Netgear manufacture.
- aalexandrebetaMar 01, 2017Master
Try on NTFS!
- StephenBMar 01, 2017Guru - Experienced User
wpslo wrote:
Hello, The file structure is "exFAT"That's the problem. The current list is here: https://kb.netgear.com/7009/ReadyNAS-OS-6-USB-Port-use?cid=wmt_netgear_organic
- USB drives should have BTRFS, EXT2/3, FAT32 or NTFS format.
wpslo wrote:
PS The SDXC card is read by a NAS not of Netgear manufacture.I think you should post the suggestion of exFAT support on the idea exchange. No harm in naming that manufacturer there :smileywink:
The idea exchange is here: https://community.netgear.com/t5/Idea-Exchange-for-ReadyNAS/idb-p/idea-exchange-for-storage?topic-zoom=&sort-by=&date-range=all
- wpslo314Mar 01, 2017Guide
Thank you StephenB.
