Wenzu1981
Jun 02, 2022Aspirant
RN31400 – ReadyNAS 300 Series - Volume Data RAID Level 5 Innactive
Hi I have a Netgear Ready NAS 314. I recently have experienced an issue with my Ready NAS. Firstly I was not getting an IP address and had to do an OS Reboot to try and re-establish a connect...
Jun 02, 2022Guru - Experienced User
Wenzu1981 wrote:
Would remounting the volume result in data loss?
Whatever caused the mounting problem could also have created some data loss. There's no way to tell at this point.
Wenzu1981 wrote:
what is the process of doing this?
There are multiple causes, and also more than one possibility for remounting. Which is why I usually point people to support.
Wenzu1981 wrote:
but my preference would be to retrieve the data. which would be about 8TB in data. Mainly video files.
Understood.
FWIW, RAID isn't enough to keep your data safe. A backup plan is the best way to do that. So perhaps put that in place after you (hopefully) get the data back.
Wenzu1981 wrote:
Prior to losing my IP address I tried to send a file accross to the NAS, and it stated it was write protected. I rebooted the unit and then the issues became apparent.
The NAS made the volume read-only in order to protect the data. Rebooting at that point was (unfortunately) a bad idea. If would have been better to back up the data before doing that.
Wenzu1981 wrote:
I have downloaded the logs, however I don't know what to do with them.
Mods, and possibly support will want to review them. Don't post the full zip publicly, as there is some privacy leakage.
They are confusing, but you can look in system.log, kernel.log, and systemd-journal.log for btrfs and disk errors.
Wenzu1981 wrote:
everywhere I go it states that I am out of warranty and am not sure where to go to obtain a support contract.
If you log into my.netgear.com, and look at your registered product list then you should see a "support options" control on the right (right under "Product Info"). One of those options should be "purchase a support contract"
But wait for the mods ( Marc_V , JeraldM ) to chime in. I just tried clicking on that link on my RN526X, and it isn't actually giving me the option to purchase.
Wenzu1981
All support options being Phone, Chat and email have expired. Also hardware, accessory and power supply warranties have expired as well.
There is no option to purchase a support contract, however there is an option to activate a support card, however in order to do this I require a support contract with an activation key.
As all warranties and support have expires as the product is more than 5 years old, does this mean Netgear will not provide support?
