dvirgeva
Aug 27, 2020Aspirant
RN31400 gets stuck when starting
Please help. I receieved for a couple of days this message via email from my ReadyNAS device: "System volume root's usage is 91%. This condition should not occur under normal conditions. Contact te...
Marc_V
Aug 27, 2020NETGEAR Employee Retired
Welcome to the Community!
This is due to the system root volume getting full, this usually occurs when an app stores it's data on the system volume or logs accoumulate. The NAS experiences degradation of performance and in this case the services were not running now since the system volume is already full making the NAS admin page not accessible and even booting up getting stuck.
You may want to try booting the NAS on Read-Only mode and see if data will become accessible for you to do a full backup but the best option right now is to contact Support and have a case escalated to higher tier for them to fix the issue.
How to boot the NAS on Read only mode
HTH
dvirgeva
Thanks Marc,
Unfortunately the NAS is out of support and end of life so the interface wouldn't let me report anything to them.
I will first try to get the NAS up and get the information backed-up so that I can get safely more adventurous with finding a solution.
- StephenBAug 27, 2020Guru - Experienced User
If you are the original owner, then you can still get software support via my.netgear.com. You do need to pay for it. You don't want the gearhead support, that doesn't cover it. There is a per-incident support option, though you may need help from JohnCM_S or Marc_V to get it. Cost would be around $75 USD.
There might also be a lifetime chat support option for your particular NAS - that would apply if you purchased it between June 1, 2014 and May 31, 2016.
After you resolve this, I suggest putting a backup plan in place for the NAS (waiting until the NAS fails to make a backup isn't a good strategy).
Are you familiar with the linux command line interface? Accessing the system in tech support mode isn't difficult, but you do need to be careful when cleaning up the OS partition. There is also some risk that your NAS configuration files have been corrupted. There is a script that can be run to re-build them, but if you aren't up to speed on linux it would be best to use paid support.
- dvirgevaAug 27, 2020Aspirant
Thank you Stephen.
I am sorry about not having backup in place, however, having that this device offers redundancy already and I do have other similar devices on standby in case of any hardware failure, I didn't expect a software Bug to be putting the device out of use.
I am busy with the support trying to get access to the data at the moment.
Do you have any guidance on how to connect to the device once it is in Tech Support mode?
Thank you so much for your help.
Dvir- StephenBAug 27, 2020Guru - Experienced User
If you are working with support, then it's best to let them lead. They'll connect remotely, and resolve the problem for you.
If that doesn't work out, post back and I can give you some basic information on how to reach the NAS locally when it's in tech support mode. Gaining access is easy - the tricky part is figuring out what is using the space, and knowing what needs to be deleted.
Of course it's your data, and how much protection it needs depends on what it is. That said, RAID isn't enough to keep it safe. Hardware failures, software failures, user error, malware, theft, fire, power surges (among other things) can all result in loss. So if keeping your data safe matters to you, you do need to have a backup plan.
However, support can easily deal with a full OS partition, so if that is the only issue it should be quickly resolved.
FWIW, in most cases this is caused by a third-party app. Though there are some scenarios where the ReadyNAS application can also cause it.
