vsedd
Jun 28, 2021Follower
RN316 - Increase number of concurrent connections
Hello! We currently have a number of users remotely and connecting to our server via MountainDuck. While it's been great to have the server mounted as a volume directly instead of using an FTP conn...
Sandshark
Jun 29, 2021Sensei
If you are doing a lot of remote access, a VPN may be a better solution. I personally choose ZeroTier for that, but OpenVPN (especially if supported by your router) is another option. They work a little differently from each other, so which you choose depends a lot on your use case. And unlike MountainDuck, both of those options are free (with a limit of 50 users for ZeroTier).
