jonasl
Jul 21, 2013Aspirant
RN316 6.0.8 will not execute /etc/init.d/-scripts on boot
Hi all,
I am a long time user of the NVX model who just upgraded to the 316 running OS 6.0.8.
Since I really appreciate dnsmasq, and have been running it on the NVX for years, I thought I should install it on the 316 as well. Everyting works just fine except that I can't make the RN start dnsmasq on boot.
I have done the usual:
The correct init.d run level links seems to exist:
Running the the init script on the command line or "service" both works equally good:
If anyone of you could give me some kind of hint where to look next, I would appreciate it a lot!
Thanks!
Jonas
# apt-get update && apt-get upgrade
# apt-get install dnsmasq
# ls -l /etc/rc*/*dnsmasq*
lrwxrwxrwx 1 root root 17 Jul 19 23:15 /etc/rc0.d/K02dnsmasq -> ../init.d/dnsmasq
lrwxrwxrwx 1 root root 17 Jul 19 23:15 /etc/rc1.d/K02dnsmasq -> ../init.d/dnsmasq
lrwxrwxrwx 1 root root 17 Jul 21 20:22 /etc/rc2.d/S01dnsmasq -> ../init.d/dnsmasq
lrwxrwxrwx 1 root root 17 Jul 21 20:22 /etc/rc3.d/S01dnsmasq -> ../init.d/dnsmasq
lrwxrwxrwx 1 root root 17 Jul 21 20:22 /etc/rc4.d/S01dnsmasq -> ../init.d/dnsmasq
lrwxrwxrwx 1 root root 17 Jul 21 20:22 /etc/rc5.d/S01dnsmasq -> ../init.d/dnsmasq
lrwxrwxrwx 1 root root 17 Jul 19 23:15 /etc/rc6.d/K02dnsmasq -> ../init.d/dnsmasq
#service dnsmasq start
#/etc/init.d/dnsmasq start
Thanks!
Jonas
- super_poussinVirtuosoAn example to help you
/lib/systemd/system/mysqld.service
[Unit]
Description=MySQL Server
After=network.target
[Service]
Type=forking
ExecStart=/etc/rc.d/mysqld start
ExecStop=/etc/rc.d/mysqld stop
[Install]
WantedBy=multi-user.target - jonaslAspirantSuper-poussin, thanks for sending me off in the right direction! And also for having an old Unix guy learn systemd basics.... :wink:
What was missing was trivial....
root@nas:~# systemctl enable dnsmasq
Sorry for asking this kind of trivial question, but nevertheless, I was greatly helped!
Thanks,
Jonas - super_poussinVirtuosoYou're welcome
- ozieboyAspirantHi Everyone,
Fist post. Fist of all, these forums are really great. I learnt a lot.
Sorry to revive this old post, but I am trying to setup softether VPN on my ready nas ultra 2. Its running OS 6.1.1 (also tried 6.0.8).
One of the requirements to setup "Softether VPN server " is to install "dsnsmasq". It installs fine but then the service fails to start with systemctl.
Do I also have to install "Network support "? Can someone point me to right direction, please?
Also, is there a way to have the third party add-ons installed like "Softether" to show up as an icon in the frontview ?
