Mook2
Apr 04, 2020Aspirant
RN316 Corrupt Files
Once again I'm having issues with BTRFS errors. 020-04-04 14:54:44: BTRFS critical (device md126): corrupt leaf, bad key order: block=20728614748160, root=1, slot=404 Earlier I had this error...
Mook2
Hi Stephen, this is my backup box.
I neglected to mention this was in my log:
"readynas volume data encountered an error and was made read-only. It is recommended to backup your data."
I'll send the logfile and see what happens,
This is so disheartening,
Dave-
Apr 04, 2020Guru - Experienced User
Yeah. And the recurrance is a puzzle. Hopefully a log analysis will give some clue.
- SandsharkApr 04, 2020Sensei
What drive type(s) are you using? Some "green" desktop drives do no behave well in a RAID array. Mixing them with others can be especially troublesome.
- Mook2Apr 04, 2020Aspirant
Hi sand,
These are all Western Digtal Red. I tested them all before I installed them.
I have 5 ReadyNAS boxes. 3-316s and 2 Ultra6s running OS6,
4 of 5 have segfault errors. I honestly have zero faith in Netgear. This started after I updated to 6.10.2. There's an earlier issue I posted that Stephen helped me "solve" but that box now has a segfault error.
I'm not happy. If I had the money I dump these for something else.
Dave-
- StephenBApr 05, 2020Guru - Experienced User
I'm running three OS-6 ReadyNAS (RN526, RN524, RN202) with WD Reds, which are running 6.10.3 at the moment. I've never seen this on any of them.
Have you tried running smartctl -x using ssh? This will report disk errors that might have rotated out of the logs. I discovered a couple of WD60EFRX drives were generating occasional UNCs that way in my RN526. There was nothing in the normal smart stats.
Stephen, I can only hope this can be solved.
