stevef69
Aug 04, 2025Follower
RN316 local config file ?
Hi, We have a RN316 6 bay device in one of our remote offices, The local IT tech decided to pull the drives and appears not to have installed back in the same slots. My question is . Does t...
Aug 04, 2025Guru - Experienced User
stevef69 wrote:The local IT tech decided to pull the drives and appears not to have installed back in the same slots.
The system should boot and assemble the RAID array anyway. Is this not happening?
You could try accessing with ssh, and then entering mdadm -D /dev/md127
