q3d
Apr 27, 2025Aspirant
RN316 Samba Configuration files
Hi there, I was looking at diagnosing a samba file share 'same files showing multiple times' when accessing a device (USB) on the ReadyNAS (RN316) that is samba shared (using OS 6.10.8 - stable). ...
Sandshark
Apr 28, 2025Sensei
First off, you are misinterpreti8ng the priority. If there are conflicting configurations, the last one given overrides the others, not the first. So anything in /etc/frontview/samba/Shares.conf that contradicts something in /etc/frontview/samba/Shares.conf will override.
If you look in /etc/frontview/samba/Shares.conf and you will see configurations by share name for shares in your data volume..
/etc/frontview/samba/addons/addons.conf seems to be included so addons can make changes that aren't in the others so they don't get overwritten by the OS. That's where you should put any changes you have for your data volume shares so they, too, don't get overwritten.
Having no attached USB drive, my /run/usb/samba/Shares.conf is empty. I've actually never had a USB drive connected, so I don't even know if it survives dismount and remount of a drive. But based on Netgear's naming scheme, I'll bet it contains the configurations for shares on a UBS drive. Have you looked at yours?
- q3dApr 28, 2025Aspirant
The order list for includes is standard - top down, and yes the lower entries over-ride the higher entries...
The /run/usb/samba/Shares.conf file contains auto-generated (auto-mounted) USB drives, so the path's are defined there...since /etc/frontview/samba/addons/addons.conf is before it, i don't see how i can define settings for a path that yet to be defined. that was the issue.
So the /etc/samba/smb.conf is as follows# This file is auto-generated. Do not modify! [global] include = /etc/frontview/samba/smb.conf.defaults #dashboard: allow trusted domains = 0 dos charset = CP1252 hostname lookups = 0 map to guest = bad user oplocks = 1 spotlight:fts = 1 #dashboard:#dashboard:orgunit = #dashboard:#dashboard:no_sync_ads = #dashboard:idmap config SIMPSONS : backend = rid #dashboard:idmap config SIMPSONS : range = 32768 - 2000000000 #dashboard: password server = * #dashboard: include system krb5 conf = 0 realm = security = user template homedir = /home/%U workgroup = SIMPSONS ldap timeout = 15 #dashboard: #dashboard:domain_admin_user = vfs objects = catia fruit streams_xattr acl_xattr snapper btrfs include = /etc/frontview/samba/smb.conf.%a include = /etc/frontview/samba/smb.conf.overrides include = /etc/frontview/samba/Shares.conf include = /etc/frontview/samba/Shares.conf.%G include = /etc/frontview/samba/addons/addons.conf include = /run/usb/samba/Shares.conf include = /etc/frontview/samba/timemachine.conf [homes] browseable = 0 writeable = 1 public = 0 valid users = %D\%S
ie# /etc/frontview/samba/smb.conf.defaults contains: client max protocol = SMB3 dbwrap_tdb_mutexes:* = yes delete readonly = 1 #...etc.. # /etc/frontview/samba/smb.conf.overrides contains: server signing = auto #case sensitive = auto # /etc/frontview/samba/Shares.conf contains: #....NAS data drive mounts... # /etc/frontview/samba/addons/addons.conf does not exist (default with no apps/addons installed) # /run/usb/samba/Shares.conf contains: [USB_HDD_2] path = /media/USB_HDD_2 comment = "Store Drive" spotlight = 0 admin users = +admin read list = "user1","user2","@users" write list = "email1@mail.com","user2",+admin valid users = "email1@mail.com","user2","@users",+admin #...etc.. #...other auto-mounted USB drives.. # /etc/frontview/samba/timemachine.conf contains: # DO NOT EDIT.So I don't see how adding any USB drive settings before the path is even defined will work
[YourShareName] locking = yes fruit:locking = none
This is what happens when settings occur before its pathed..# testparm -s | grep -A 5 '[USB_HDD_2]' Registered MSG_REQ_POOL_USAGE Registered MSG_REQ_DMALLOC_MARK and LOG_CHANGED Load smb config files from /etc/samba/smb.conf Processing section "[USB_HDD_2]" WARNING: No path in service USB_HDD_2 - making it unavailable! NOTE: Service USB_HDD_2 is flagged unavailable. # ...etc...Yet the drive is available and accessible fine otherwise.
and since it's an auto mounted USB drive that is pathed in /run/usb/samba/Shares.conf .... i dont see how /etc/frontview/samba/timemachine.conf is something that can be manually added to.
Global settings can be used with /etc/frontview/samba/smb.conf.overrides but it appears that it's not possible to set specific USB drive settings with the current format of /etc/samba/smb.conf and its includes.- StephenBApr 28, 2025Guru - Experienced User
If you add your settings to /run/usb/samba/Shares.conf as a test, does that solve your problem?
- SandsharkApr 28, 2025Sensei
Do the entries for a USB drive get deleted when you dismount it? If so, then putting in manual entries is only temporary unless you never dismount the drive. As I said, I've never attached a USB drive to my NAS, so I simply don't know. Unfortunately for you, it makes complete sense to me that you can't put in configuration options for a share that's not always there.
The alternative would be to enable the option globally and then disable it on every other share -- certainly not a preferred method.
