mrg99991
Dec 19, 2014Aspirant
RN316 (touchscreen) graceful shutdown
I can't find a way to gracefully shutdown this new RN31600/. My older RN6000, have a power button at front, and pushing it 3 times shuts down gracefully, or I can SSH an do it.
How do I perform this with the RN31600 ?
The manual says push the power button 3 times, but the person who wrote it has never used this touch screen device. I've tried holding the OK button and push the arrow keys and no joy.
I can't find a shutdown button in the GUI either. (it's in radiator on my nas pro)
Can someone helps. I'm on a UPS, and it will run out of juice soon, I don't just want the disks to crash.
Mr.G
Mr.G
- vandermerweMasterThere is a button, inside the front door of the 316 ( bottom right). This is the button referred to in the manual.
If the oled display is off, it's 3 presses, each press is associated with a message in the oled display. - mrg99991AspirantThanks Vanermerwe
Sorry , I have poor eyesight.
I see, it's a black button on a black background, behind the door. The old one the button is outside and illuminated. I supposed they save 5cents for the led. 2 presses shut it down.
I also found the shutdown button in the gui, after I searched the html source.
The manual is a bit lame - vandermerweMasterWhy does your nas not monitor the UPS and shut down automatically?
- mrg99991AspirantSometimes, you want to shut it down manually.
