TangoWhiskey123
Jun 21, 2019Aspirant
RN316 updated Firmware to 6.9.3 and now have no volumes
I did the firmware upgrade to 6.10.1 and everything seemed to be going well unitl the unit needed to restart. Then it wouldn't. The blue power light just blinked. RAIDar says the unit is starting, ...
Jun 21, 2019Guru - Experienced User
You should consider using paid Netgear support (my.netgear.com) for this.
BTW If you purchased your NAS (new) between 1 June 2014 and 31 May 2016 you have free lifetime chat support.
- TangoWhiskey123Jun 21, 2019Aspirant
How do I find out about the free support? I bought it new Dec 2015 and free support would be nice.
- StephenBJun 21, 2019Guru - Experienced User
You should be able to get it via my.netgear.com.
When I give them my serial number and purchase date, they do not offer any support other than paid. They point me to this forum.
This firmware update isn't working out too well. If I knew that paid support would fix it, I might go for it. But based on my experiece so far, I will pay and they will tell me there is nothing they can do. I don't have a lot of confidence in Netgear at this point since it is thier update that caused the issue and then they offer no meaninful support.
