joe_schmo
Oct 08, 2022Tutor
RN316 Upgraded Firmware, EDA500 Volumes are messed up
I just upgraded my firmware. machine booted and then one of my EDA500s doesn't show up. The other is also messed up. Doesn't seem that netgear provides support anymore... I used to be able to b...
joe_schmo
Oct 10, 2022Tutor
So if I disconnect the two EDA500s, my NAS boots up and all is well.
If I turn one of the EDA500s on, it shows up as a mix of unusableness.
If I boot up the NAS while the two EDA500s are powered on and connected, the NAS shows every drive as red.
I am assuming there is something I can do to fix this. Support tells me to post to the forums and won't tell me if you can purchase a support ticket like back in 2018.
Anyone have any ideas?
- joe_schmoOct 10, 2022Tutor
more info...
Without the EDA500s on, I see my NAS showing up in the Volumes part with
EDA1
EDA2
EDA3
All with data/free at 0.
I only ever had 2 EDA.
So wondering if anyone can help tell me what to do to get these back.
- StephenBOct 10, 2022Guru - Experienced User
joe_schmo wrote:
If I turn one of the EDA500s on, it shows up as a mix of unusableness.Does it matter which one? Or does turning either one on cause this problem?
It's both. Here's a screenshot with what happens when I boot the NAS by itself and then turn on one EDA.
Have you captured a full log zip file? I am suspecting that the two EDA500 volumes are out of sync. Sandshark might have some suggestions (he has had EDA500s in the past, I have not).
FWIW, I think you must have vertically expanded your EDA500 volumes (that would explain the three eda1 RAID groups).
