RandomNASChap
Jun 10, 2017Aspirant
RN316 works with CyberPower Value 1000EI
Just a note for anyone searching that I can confirm the ReadyNAS model RN316 six-bay running firmware 6.7.4 works properly with the CyberPower Value 1000EI. Specifically - the CyberPower Value 1...
RandomNASChap
Specific links in case they matter:
https://www.cyberpower.com/au/en/product/series/Backup%20UPS%20Systems/Value%20SOHO
https://www.cyberpower.com/au/en/product/sku/Value1000EI
CyberPower Value1000EI offers home and office users a reliable battery backup and safeguards office PCs, network communication equipment, and other electronic devices from surges, spikes, brownouts and other power incidents. Designed with GreenPower UPS™ Technology to improve operating efficiency and to minimize energy consumption, users can enjoy significant energy cost savings over conventional UPS systems. The UPS provides Automatic Voltage Regulation (AVR) to maintain safe voltage for connected equipment. The featured data line protection protects phones, networks, and other communication equipment against surge/spikes and other power irregularities.
FEATURES
- Line-interactive UPS Topology
- Energy Saving Technology
- Simulated Sine Wave Output
- Automatic Voltage Regulation (AVR)
- Surge and Spike Protection
- Phone/ Fax/ Modem/ DSL/ Network Protection
- PowerPanel® Management Software
- Tower Form Factor
GENERAL
UPS Topology Line-interactive
Energy Saving Technology GreenPower UPS™ Bypass Technology
INPUT
Nominal Input Voltage (Vac) 230 ± 10%
Input Voltage Range (Vac) 170 ~ 290
Input Frequency (Hz) 50 ± 5 60 ± 5
Input Frequency Detection Auto-sensing
Rated Input Current (A) 4.55
Input Connector Type IEC C14
Detachable Power Cord Plug Type AU
Power Cord Length (ft.) 6
Power Cord Length (m.) 1.8
OUTPUT
Capacity (VA) 1000
Capacity (Watts) 550
On Battery Waveform Simulated Sine Wave
On Battery Voltage(s) (Vac) 230 ± 10%
On Battery Frequency (Hz) 50 ± 1% 60 ± 1%
Automatic Voltage Regulation (AVR) Single Boost, Single Buck
Overload Protection Fuse
Outlet(s) - Total 2
Outlet Type AU x 2
Outlet(s) - Battery & Surge Protected 2
Typical Transfer Time (ms) 4
BATTERY
Runtime at Half Load (min) 7
Runtime at Full Load (min) 1
Typical Recharge Time (Hours) 8
Start On Battery Yes
User Replaceable No
Battery Type Sealed Lead-acid
SURGE PROTECTION & FILTERING
Surge Suppression (Joules) 125
EMI/RFI Filtration Yes
Phone/Network Protection RJ11/RJ45 (Combo) 1-in, 1-out
MANAGEMENT & COMMUNICATIONS
LED Indicators Power On , Line Mode , Battery Mode , Low Battery
HID Compliant USB Port(s) 1
Serial Port RS232
Audible Alarms Battery Mode , Low Battery , Overload , UPS Fault
Power Management Software PowerPanel® Personal Edition
PHYSICAL
Form Factor Tower
Enclosure Construction Plastic
Color Black
PHYSICAL SIZE - UPS MODULE
Dimensions (WxHxD) (in.) 3.937 x 5.512 x 11.811
Dimensions (WxHxD) (mm.) 100 x 140 x 300
Weight (lbs.) 12.125
Weight (kg.) 5.5
ENVIRONMENTAL
Operating Temperature (°F) 32 ~ 104
Operating Temperature (°C) 0 ~ 40
Operating Relative Humidity (Non-condensing) (%) 0 ~ 90
Operating Elevation (feet/meters) 0-10,000 feet (0-3,000 meters)
Storage Temperature (°F) -4 ~ 122
Storage Temperature (°C) -20 ~ 50
Storage Relative Humidity (Non-condensing) (%) 0 ~ 90
Storage Elevation (feet/meters) 0-10,000 feet (0-3,000 meters)
Online Thermal Dissipation (BTU/hr) 109
Audible Noise at 1.5M from Surface of Unit (dBA) 40
CERTIFICATIONS
Certifications CE , C-Tick , EAC
RoHS Yes
WARRANTY
Product Warranty Period (Year)2
Battery Warranty Period (Year)2
