pressplaycd
Feb 11, 2018Aspirant
RN422 OS Reinstall Stuck on "Checking root FS"
Hi
Trying to do OS reinstall through the boot menu. After selecting OS reinstall, it 's stuck "Checking root FS" for th e past 36 hours. Do I let it run as is or is there something I can do to bypass this stage.
any advise would be appreciated.
thanks
You can't bypass that check (and the OS is reinstalled onto the root FS). It's clear something is very wrong, I suggest powering down the NAS and not letting it continue.
Can you follow up with more information on what the original problems were?
- pressplaycdAspirant
Hi Stephen B
Recently changed my password for some reason and could not get into Admin page after with either new or old password. It was recommended I try to do OS reinstall to fix the issue. Now it's stuck "checking root FS" . I tried updating FW through Readycloud home page and nothing happens after clicking on "UPDATE". Any suggestions?
thanks
- mdgm-ntgrNETGEAR Employee Retired
Could be a full root volume.
So you didn’t have a password recovery question setup?
