chris_modica
Jan 08, 2020Aspirant
RN4220 / Ver6.9.2 - File Access Not Possible / "clamd" CPU usage on the NAS 99.9%
Dear Netgear Community, we are an experiencing a problem with one of our customer's NAS and I was hoping you could help us. The Model and Firmware version are as follows: RN4220 / Ver6.9.2. The probl...
chris_modica
Thanks for your prompt reply Sandshark. I will try upgrading the firmware on our test environment and see if it resolves the problem. Regards
chris_modica
Jan 15, 2020Aspirant
Dear Netgear Community. I originally said the Firmware version on the NAS experiencing the problem was 6.9.2, but, I have confirmed since then that it is actually 6.9.4. We have several customer offices using the RN422 and they all run Ver6.9.2, except for one of our customer’s RN422, which uses 6.9.4, and that’s the one the problem accessing the NAS is occurring.
Since 6.9.2 has been stable at all the offices we are using it, we feel it might be safer to downgrade the Ver 6.9.4 NAS to Ver 6.9.2, rather than upgrading to the unknown (for us) Ver 6.9.5 (and easier to convince our Ver 6.9.4 customer to downgrade to conform to the other office’s versions).
I would like to confirm, is it possible to downgrade from 6.9.4 to 6.9.2, and, is the 6.9.2 generally stable to use? I looked at the release notes for the various versions, and it seems that 6.9.4 was particularly problematic, but that 6.9.2 was ok. Does anyone have any experience with 6.9.2 or any advice on this? I really appreciate your input. Best regards
