kmmcd
Jun 12, 2017Aspirant
RN424 & positions for 2 drives
I intend to install two physical disc drives in my new RN424. Does it matter which of the four bays I install these first two drives into?
- Jun 13, 2017
One of many aspects of ReadyNAS life that we love to over-think :smileywink:
Spacing them out does no harm, and generally the disks will run a bit cooler if you do that. But the NAS is designed to run with disks in all four bays, so it works out ok either way.
mdgm-ntgr
Jun 12, 2017NETGEAR Employee Retired
No. You can put them in whichever disk bays you like. Some like to put them in bays 1 and 2 to keep things organised in a straightforward way, others like to have an empty bay in-between the disks.
- Retired_MemberJun 13, 2017
While it might look nicer to have them in bays 1 and 2, for cooling purposes it might be better two have them in bays 1 and 4 (preferred) or 2 and 4 or 1 and 3.
- StephenBJun 13, 2017Guru - Experienced User
