mlknez
Nov 09, 2018Guide
RN428 Raid 5
I have an RN428 that i want to populate with 8 10TB drives. It automatically chooses to use RAID 6. I would rather use RAID 5. Is there a way that i can specify that before it starts to build the ...
mlknez
Nov 09, 2018Guide
It is a killer to have to lose out on 20TB of storage!! As soon as I turn on the RN428 with the 8 drives in place, wont it start to build the raid 6 array? Can I interrupt it and change it to raid 5? How do I do that?
TeknoJnky
Nov 09, 2018Hero
when you have a second drive fail in the middle of a rebuild or expansion, then its going to be even more 'killer' to lose 70tb.
go into the volumes tab click the gear on the data volume and delete.
then create a new volume of the type and drives you desire.
you can choose x-raid which will default to the raid-6 mode and uses all drives and will automatically expand/rebuild, or you can choose a regular raid mode from the available options. After you create your raid 5 volume, then you can switch back to x-raid mode if you desire (and you used all the drives).
x-raid mode can only be enabled with a single volume using all drives.
