BaJohn
Jan 09, 2015Virtuoso
RN516 and control of attached APC UPS.
Using ReadyNAS RN516 with 6 4TB discs in RAID10 configuration. Connected APC UPS (CS650 400w), which was auto found by ReadyNAS. Details of UPS via Admin page came up in both <System> <Power> ...
BaJohn
StephenB wrote: Normally it just works. Did the APC come with a normal USB cable, or did you need to adapt a serial cable?
Hi Stephen
I did use the cable that came and yes it does work (as mentioned in the post), but NOT completely as I wanted (as mentioned in the post)
Could you be more specific about where you would expect to be able to 'control' the UPS.
From the admin page? If so where?
From a PC? How?
Just looked back over the above and it MAY appear rude ... that wasn't and isn't the intention :)
I am trying to get the control and testing facilities available via 'PowerChute' or something equivalent.
BJ
