BaJohn
Jan 09, 2015Virtuoso
RN516 and control of attached APC UPS.
Using ReadyNAS RN516 with 6 4TB discs in RAID10 configuration. Connected APC UPS (CS650 400w), which was auto found by ReadyNAS. Details of UPS via Admin page came up in both <System> <Power> ...
Jan 09, 2015Guru - Experienced User
I use cyberlink, so I haven't done anything with powerchute.
The NAS interface lets you set the power down threshold but that is it. You can also export the NAS monitoring to another ReadyNAS or a PC (for cases where the UPS is shared). That export uses NUT (http://www.networkupstools.org/)
You might be able to connect the UPS to the PC, and install both NUT and PowerChute there. That might allow the NAS to monitor the PC. It requires that the PC be always on though (and of course you also need a switch that is also protected by the UPS whenever you are using network monitoring).
