britesc
Dec 02, 2018Aspirant
RN524X Boot Loop
Hi,
I attempted to create a .service file for use with xteve but misspelled xteve (even after testing it I just had to make a change and screwed it)
Now systemd is reading the file and rebooting ...
Dec 02, 2018Guru - Experienced User
You can boot the NAS in tech support mode and fix this.
In tech support mode you use telnet to connect. The username is root, the password is infr8ntdebug
After that, enter
# rnutil chroot
That should start the RAID and chroot. Then you should have access to the OS partition, and you can fix the typo.
