Visario
Dec 31, 2017Aspirant
RN524X Poor write speeds over 10GB network
Hello, I've just set up a new RN524X with Ironwolf HDDs, connected to 1 PC workstation with 10GB adapter and 1 iMac with 1GB adapter, bith via a 10GB netgear switch. The speeds are as you wo...
Dec 31, 2017Guru - Experienced User
What are you using to measure the speeds? Also, what NIC card are you using in the PC?
- VisarioDec 31, 2017Aspirant
Hi Stepehn,
Thans for the response. I'm using LAN Speed Test by Tutusoft to measure the speeds on both the PC and Mac.
The NIC is StarTech (not sure which one withour checking)
- StephenBDec 31, 2017Guru - Experienced User
Can you also test with NasTester? (http://www.808.dk/?code-csharp-nas-performance) You might want to increase the test transfer to 1 gigabyte,
FWIW, your iMAC speeds are similar to what I see on my Windows 10 system, accessing an RN526x using a Netgear XS708Ev2 switch. The PC is using an Asus XG-C100C NIC. You probably should enable flow control on the switch and the PC nic card.
- VisarioJan 01, 2018Aspirant
I've tested with NAS Tester - the results are completeyly different: 630 m/b sec Write and 731 m/bsec Read
I'm not sure why this would vary so much from the LAN speed test.
I also tried enabling flow control but this had no effect.
The NAS tester did seem to wipe out the NIC card so I had to restart the machine. It did this twice.
