Tonkinite
Mar 25, 2017Luminary
RN626X Incompatible with Drives built under RN516?
Swapped my RN516 drives to my RN626X (same firmware level, 6.6.1).
Volume immediately marked unavailable on boot.
PRIORITY support tech just openly voiced that it wasn't possible.
So... No one can ever just swap drives to any of the new units!? You're supposed to build a new volume and copy the data over?
- mdgm-ntgrNETGEAR Employee Retired
Swapping disks to a new unit normally works fine, but you should update your regular backup first where possible.
I understand your current case has been escalated to L3.
- TonkiniteLuminary
The original case was just CLOSED as RESOLVED by a Netgear tech early this afternoon ET.
I subsequently filed a RN626X customer support complaint against L3.
I have 24x7 support Contacts on both units.
The L3 that reviewed your original case mounted your volume fine and rebooted it to normal mode and it came up fine and the data was accessible so he closed that case after confirming that with you.
You've since lost access to the data again and you have a new case that has been escalated to L3.
As you're still having issues the agent handling your case will need Remote Access to look into it further.
Looking at your original case notes mounting the volume read only there was a problem with the quota groups. That doesn't suggest a filesystem issue but rather the possibility that there may be an issue with the quotas on your volume that a quota rescan would fix.
