tlkohler
May 19, 2016Aspirant
RN716 - Management service is offline (OS6.4.2)
Good afternoon all I attempted to access my ReadyNAS RN716x this morning (as I normally do everyday) and was greeted with the error message that my device was not available. It is not accessible in...
- May 20, 2016
Your root partition is very full with a large MySQL database stored on the 4GB root volume.
I moved that over onto the data volume.
The LMS app is still using a few hundred MB of space.
kohdee
May 19, 2016Administrator
Management services is offline means that your ReadyNAS's database is not currently turned on. There's a few reasons why that could happen (like a full OS caused by an app, or for some reason, the database isn't started).
Try this:
http://IP_of_readynas/dbbroker?start_svc=readynasd
tlkohler
May 20, 2016Aspirant
Thanks you for the suggestion. I attempted http://IP_of_my_readynas/dbbroker?start_svc=readynasd in several browsers and none will display a page. I get "This site can't be reached. xxx.xxx.x.xxx refused to connect"
