tlkohler
May 19, 2016Aspirant
RN716 - Management service is offline (OS6.4.2)
Good afternoon all I attempted to access my ReadyNAS RN716x this morning (as I normally do everyday) and was greeted with the error message that my device was not available. It is not accessible in...
- May 20, 2016
Your root partition is very full with a large MySQL database stored on the 4GB root volume.
I moved that over onto the data volume.
The LMS app is still using a few hundred MB of space.
tlkohler
May 20, 2016Aspirant
Yes I did but I will attempt it again, both with what it should be set at and also the default.
Tried both and still the same response - "Not a valid Username or password"
mdgm-ntgr
May 20, 2016NETGEAR Employee Retired
- tlkohlerMay 20, 2016Aspirant
Okay (thanks). And so these items were/are causing an access issue? I will need to start researching these items so this does not continue to be an problem. To be honest I'm completely clueless with respect to what your telling me so I will need to do my homework. What else should I look for to minimize access issues for the future?
- mdgm-ntgrMay 20, 2016NETGEAR Employee Retired
Configuring apps to store data on the data volume rather than on the root volume is important. You can easily fill the 4GB root volume for the OS, config and logs if you store app data on it.
You must have installed an app that requires MySQL, but MySQL was installed in such a way that it was not configured to store the data on the data volume and so the database filled the root volume.- tlkohlerMay 20, 2016Aspirant
I see and you have or will configure MySQL to store the data to the data volume or I will need to research how to do this and perform the change?
By the way, thanks you so much for troubleshooting this issue.
- Jun 10, 2022Retired_Member
