tlkohler
May 19, 2016Aspirant
RN716 - Management service is offline (OS6.4.2)
Good afternoon all I attempted to access my ReadyNAS RN716x this morning (as I normally do everyday) and was greeted with the error message that my device was not available. It is not accessible in...
- May 20, 2016
Your root partition is very full with a large MySQL database stored on the 4GB root volume.
I moved that over onto the data volume.
The LMS app is still using a few hundred MB of space.
tlkohler
May 20, 2016Aspirant
I see and you have or will configure MySQL to store the data to the data volume or I will need to research how to do this and perform the change?
By the way, thanks you so much for troubleshooting this issue.
mdgm-ntgr
May 20, 2016NETGEAR Employee Retired
Yes, I have already configured that and moved the data across.
It is possible to configure that setting using SSH, but there are support implications for doing that.
- tlkohlerMay 20, 2016Aspirant
Well then since you've already corrected that issue - I'll leave well enough alone.
