ScottyRun
Jun 29, 2020Follower
RNC-4C Won't Power On
I have an RNC-4C and it has stopped powering on. Have had this unit since 2015. Just replaced the bios battery on the board, to eliminate this as an issue.
Also, while i had the unit apart, i checked all of the capacitors and board for marks and damage, and is still all good.
Have put a multimeter to the pins that connect to the unit from the power supply, but not detecting any voltage.
Any idea where i can pick up a replacement power supply in Western australia?
1 Reply
The RN314 has a 5 year warranty - so I'd begin by checking the warranty status on my.netgear.com. Do you still have the proof-of-purchase? Often on-line sellers will keep order information for some years (Amazon certainly does).
