pefinaz
Nov 13, 2022Aspirant
rnd4000 readynas nv v1 third party OS
Does anyone know if there are any third party OSs That can be installed onto this NAS? I have found things like this for old Netgear routers, so I thought that someone might have done something simil...
Nov 13, 2022Guru - Experienced User
pefinaz wrote:
Also, can I install the software that allows me to access the NAS setting on Windows 10 pro.
If you mean Frontview, then look here:
- SandsharkNov 14, 2022Sensei
Given the ancient SPARC processor in that NAS, you aren't going to find anything up to date that can be installed.
- pefinazNov 14, 2022Aspirant
Is Frontview the same as RAIDar?
Is there a certain version of RAIDar/Frontview that I need to install for my RND4000?
Do you know where I get a version of RAIDar/Frontview that works on Windows 10 pro?
Is there any documentation for installing and using RAIDar/Frontview?
Thanks
Paul
No, FrontView is the built-in GUI, at https://<IP or name of ReadyNAS>/admin. RAIDar isn't even needed at all, though it is helpful in accessing FrontView from it's buttons and getting a quick lok at status.
So I got into the NAS using the PailMoon browser using:
http:(it's address)/admin
Then I looked at all the pages I use to see.
Then I logged out and tried to log back in and was not able to get in again.
Any idea why?
Thanks,
Paul
