pefinaz
Nov 13, 2022Aspirant
rnd4000 readynas nv v1 third party OS
Does anyone know if there are any third party OSs That can be installed onto this NAS? I have found things like this for old Netgear routers, so I thought that someone might have done something simil...
Nov 13, 2022Guru - Experienced User
pefinaz wrote:
Also, can I install the software that allows me to access the NAS setting on Windows 10 pro.
If you mean Frontview, then look here:
pefinaz
Nov 14, 2022Aspirant
Is Frontview the same as RAIDar?
Is there a certain version of RAIDar/Frontview that I need to install for my RND4000?
Do you know where I get a version of RAIDar/Frontview that works on Windows 10 pro?
Is there any documentation for installing and using RAIDar/Frontview?
Thanks
Paul
- SandsharkNov 14, 2022Sensei
No, FrontView is the built-in GUI, at https://<IP or name of ReadyNAS>/admin. RAIDar isn't even needed at all, though it is helpful in accessing FrontView from it's buttons and getting a quick lok at status.
- pefinazNov 14, 2022Aspirant
So I got into the NAS using the PailMoon browser using:
http:(it's address)/admin
Then I looked at all the pages I use to see.
Then I logged out and tried to log back in and was not able to get in again.
Any idea why?
Thanks,
Paul
- SandsharkNov 15, 2022Sensei
I'm not familiar with that browser. Could it have updated between your attempts? What error message are you seeing?
BTW, you need to use https, not just http, though the NAS will normally re-direct you there.
