Fairperson
Feb 23, 2012Aspirant
RND4000 V2 - reports different disk capacities on Dashboard
I have recently purchased a RND4000 V2, hoping to supplement my existing V1 NAS. The V2 is fully populated with two (2) 2TB drives and two (2) 1TB drives. It's interesting to see that the System Dashb...
Fairperson
Feb 27, 2012Aspirant
Greetings,
Tried a few things to resolve this without much luck. I think you are spot on with the NAS trying to do a vertical expansion as I was slowly introducing 2TB drives into the system one at a time, replacing the 4 x 1TB drives. On the third disk the system reported a disk failure and I re-inserted the 1TB drive while I ran diagnostics on the drive. After 48 hours of testing using WD diagnostics the 2TB drive looks Ok and I am inclined to believe the NAS V2 is a lot more "fussy" over the drives than the V1 model I have.
After spending nearly a month of trying to get this NAS ready for doing some real work I'll leave it as is until space becomes a problem. I'll just remember to back up a lot and await some sort of failure.
Thanks for your help & feedback.
