Ed_J
Mar 30, 2013Aspirant
RNDP4000 No Network Connection or Boot
Hi, Just joined the forum. I've recently purchased a second hand RNDP4000 (diskless) on a spares/repair basis. It was cheap so decided to take the risk. However, I think the Network interface is dea...
Ed_J
Hmmm, definitely not active, so I still think that there is probably a problem with the hardware there.
Will check the drive later, but no reason to suspect it.
I tried each drive bay - same result for each. I noticed there is a green LED on the motherboard that flashes for a few seconds while it starts up, then it goes out and stays out. Any idea if that signifies anything?
The Drive is a 3TB, and there is a label on the back of the NAS that states FW: V4.2.15, so I don't think it is that old, is it?
Have you got a link to the USB recovery procedure, just in case it comes to that? If it does corrupt the EPROM, is that the end of it, or is it still recoverable/usable from there?
Thanks again.
Thanks again.
