Ed_J
Mar 30, 2013Aspirant
RNDP4000 No Network Connection or Boot
Hi, Just joined the forum. I've recently purchased a second hand RNDP4000 (diskless) on a spares/repair basis. It was cheap so decided to take the risk. However, I think the Network interface is dea...
mdgm-ntgr
Mar 30, 2013NETGEAR Employee Retired
Did you try booting into tech support mode with no disks installed? Did you try with each NIC on the NAS, different ethernet cables and different ports on your router/switch?
Here are the instructions for USB Boot Recovery: http://home.bott.ca/webserver/?p=166
