wcasanov
Sep 20, 2020Aspirant
RNDP400u stuck at 99% after upgrade from firmware 4 to 6
Attempting to upgrade firmware from Radiator 4.19 using R4toR6_6.9.5.bin. Device does not boot past 99%. Is it possible to restore the original firmware? Any options to salvage the device? I apprecia...
- Sep 20, 2020
Thanks for your reply. That is exactly what I tried. The initial boot got stuck at 94%, the factory reset with 1 disk got to 99%. I also tried an OS reinstall with similar results. All get stuck somewhere in the 90% range on upnphttpd.service.
Sep 20, 2020Guru - Experienced User
wcasanov wrote:
Attempting to upgrade firmware from Radiator 4.19 using R4toR6_6.9.5.bin. Device does not boot past 99%. Is it possible to restore the original firmware? Any options to salvage the device? I appreciate any input towards resolving this issue.
Maybe first try a single disk (doing a factory install), and see if that boots.
wcasanov
