ajwhitewolf
May 06, 2019Aspirant
RNDU 2000 raidar says corrupt root
I hope i am doing this right, if not please forgive me.
I have an older unit that i purshacsed some time ago. it has a lot of data that I need to access and put on back up clouds.
non ...
May 07, 2019Guru - Experienced User
ajwhitewolf wrote:
is the corrupt root on the unit itself? or is that on the 2tb hard drive in the bay?
The root is on the hard drive. All ReadyNAS install the operating system on a small partition on the hard drive, and boot from it. This error says that the OS partition isn't bootable. It is quite possible that you also have data loss.
The next step is to power down the NAS, and connect the drive to a windows PC. The PC can't read the file system, but you can use vendor tools to test the disk drive. Use Seatools for Seagate drives, and LifeGuard for Western Digital.
You can also try a free utility (r-linux for windows), and see if it can find your data. https://www.r-studio.com/free-linux-recovery/
If you are the original purchaser of the NAS, you could also use Netgear's data recovery service: https://kb.netgear.com/69/ReadyNAS-Data-Recovery-Diagnostics-Scope-of-Service
ajwhitewolf wrote:
curious if i purchased the unit off ebay without disks if i could just put the disk in the replacement unit and be able to get that data off the disk?
No, it won't. The problem is on the disk itself, so switching to a different chassis won't help.
ajwhitewolf wrote:
any help would be greatly appreciated i operate a n independent broadcast and need those files!
Hopefully you will be able to recover them. After you do, you should put a backup plan in place for your data. Devices can/do fail at any time.
ajwhitewolf
May 07, 2019Aspirant
thank you for this explanation. i searched and searched and was not finding the info. many links that existed in documentation were dead links.
before this recent comeplete lock out. i restarted the unit a couple of times and the problem went away.
I stumbled across a reset and power button aspect. but when i press the reset button, then the power button. the unit just turns on , then off. which isn't what the directions says for getting into the menu aspect.
- StephenBMay 07, 2019Guru - Experienced User
You might not be using the exact directions. Look on pages 14-15 here: http://www.downloads.netgear.com/files/GDC/RNDU2000/ReadyNAS_Ultra_UltraPlus_NVX_Pro_HW_en_8July11.pdf
Be very careful on the boot menu - the factory default is destructive, and you will lose your data if you accidently choose it. The only option there that could possibly help you is the OS reinstall - and the odds of that fixing your problem are pretty small.
- ajwhitewolfMay 07, 2019Aspirant
I will try it again later. but was pretty sure i was doing it the way described.
-turn unit off
-press reset then power button while holding reset.
-various lights are suppose to come on
it just shuts back off . i will try again in a little bit. i do appreciate your efforts. i have been trying to figure this out for weeks now. i have since purchased a 2tb cloud account. but need to get into the hard drive to move the files. prior to this i didn't have a way to back up all of those files. there are so many.
Once you get the files off, you can zero the disk drive, and then insert it back into the NAS. It will automatically do a factory install. Then you can reconfigure it, and copy the files back.
