ajwhitewolf
May 06, 2019Aspirant
RNDU 2000 raidar says corrupt root
I hope i am doing this right, if not please forgive me.
I have an older unit that i purshacsed some time ago. it has a lot of data that I need to access and put on back up clouds.
non ...
ajwhitewolf
May 07, 2019Aspirant
thank you for this explanation. i searched and searched and was not finding the info. many links that existed in documentation were dead links.
before this recent comeplete lock out. i restarted the unit a couple of times and the problem went away.
I stumbled across a reset and power button aspect. but when i press the reset button, then the power button. the unit just turns on , then off. which isn't what the directions says for getting into the menu aspect.
May 07, 2019Guru - Experienced User
You might not be using the exact directions. Look on pages 14-15 here: http://www.downloads.netgear.com/files/GDC/RNDU2000/ReadyNAS_Ultra_UltraPlus_NVX_Pro_HW_en_8July11.pdf
Be very careful on the boot menu - the factory default is destructive, and you will lose your data if you accidently choose it. The only option there that could possibly help you is the OS reinstall - and the odds of that fixing your problem are pretty small.
- ajwhitewolfMay 07, 2019Aspirant
I will try it again later. but was pretty sure i was doing it the way described.
-turn unit off
-press reset then power button while holding reset.
-various lights are suppose to come on
it just shuts back off . i will try again in a little bit. i do appreciate your efforts. i have been trying to figure this out for weeks now. i have since purchased a 2tb cloud account. but need to get into the hard drive to move the files. prior to this i didn't have a way to back up all of those files. there are so many.
- StephenBMay 07, 2019Guru - Experienced User
Once you get the files off, you can zero the disk drive, and then insert it back into the NAS. It will automatically do a factory install. Then you can reconfigure it, and copy the files back.
- ajwhitewolfMay 07, 2019AspirantAh very good. I thought the unit was toast. I paid a lot for that thing brand new.
Do you know if the hard drive kit to usb that i have will work with that software link you sent me? Just purchased a universale one.
