NASNoob11
Jun 27, 2012Aspirant
RNDU2000-100NAS ??
I am considering buying a pair of RNDU2000-100NAS. From what I see and read ATM, this device appears to be the previous DUO elevated to an X86 (Intel) platform. Am I roughly correct?
mdgm-ntgr
Jun 28, 2012NETGEAR Employee Retired
Yes this would work.
You can use Frontview backup to migrate the data across. I'd use NFS for the full backup then change the backup job properties to use Rsync for the incrementals.
The UI is the same UI you're familiar with on the Duo (v1)
