snoopy888
Aug 05, 2022Aspirant
ReadyNAS 2000 Issues¬
Hi I was given this NAS and im struggling to set it up. RAIDar is showing corrupt root. I have tried to perform a factory reset and OS install using the reset button to no avail. I cannot get to ...
- Aug 05, 2022
snoopy888 wrote:
Disk is WD Red NAS drive WD60EFRX
Ok. The WD60EFAX is SMR, so not a good choice. But the WD60EFRX should be fine.
I do recommend removing the partitions in the windows disk manager. Maybe also test it with WD's dashboard utility while it is connected.
If the partitions are all removed, then the NAS should automatically do a factory install when the system powers up. No need to use the boot menu.
snoopy888
Hi Stephen!
Just says ReadyNAS on the front, underneath its Model No.: RND-2A and RNDP2000 as well as RNDP2230-100NAS
Aug 05, 2022Guru - Experienced User
Ok. Then this is a ReadyNAS Pro 2. Instructions for the boot menu are on pages 14-15 here:
Do the factory default.
This model can be converted to run OS-6 (current firmware) if you wish. Though it's possible the previous owner already did this, so probably best to circle back to that after you get the NAS running.
If your NAS is still running 4.x firmware, then you will not be able to connect to the admin page with most browsers. Browsers have recently dropped support for TLS 1.0 (which is all OS-4 supports). You can connect with Internet Explorer or Edge in IE mode. Another option is to download an older version of FireFox, and configure it to not autoupdate. 94.0.2 works (among other versions).
Converting to OS-6 would eliminate the browser problem, and also provide SMB 3 support (among other things).
- snoopy888Aug 05, 2022Aspirant
It must still be running v4 because I cant get to the admin page in IE or Edge IE mode.
I tried the factory reset - once I run this mode - how do I know the reset is complete? Does it reboot automatically or do I need to reboot it myself?
Can I jump to OS6 manually somehow?
Thanks
- StephenBAug 05, 2022Guru - Experienced User
You can't get to the admin page because the OS isn't properly installed on the disks (that is the significance of the corrupt root).
The error due to TLS 1.0 would either refer to the SSL protocol or a Cipher mismatch.
After you start the reset, there will be a 5-10 minute delay before it begins. The process will include reformatting the disk and installing the OS. The NAS won't need to be rebooted afterwards.
Unfortunately, there is no simple way to tell it is finished. You could try accessing the admin web page after 15-30 minutes - that likely will be more than long enough if you are only using a single disk.
Get the NAS running first, and then we can talk about the conversion. One aspect is that I do strongly recommend upgrading the RAM in the Pro 2 before converting it. And as I mentioned, it might already be running OS-6.
So I did the reset and left it for 30mins - I still cant get to the admin page in any browser and RAIDar is still showing corrupt root.
What should I try next? Can I not reflash it using a USB stick?
If so, how - and what version do I install if I dont know if its 4 or 6?
