Bralle
Jun 30, 2021Aspirant
RNDU4000 bricked?
Hi I bought a used Readynas RNDU4000 and i tried to upgrade the FW to 6. Seems that something might have gone wrong and i can't figure out if it's possible to get it right again. When i try to ...
Jun 30, 2021Guru - Experienced User
Bralle wrote:I bought a used Readynas RNDU4000 and i tried to upgrade the FW to 6.
What steps did you use? In partiticular, did you install the prep add-on?
Bralle wrote:
When i try to start it up i just get "do_exit+4aa" OS reinstall and such doesn't work either.
Did you try a factory default from the boot menu?
- BralleJun 30, 2021Aspirant
Hi
Gonna see if i can find the guide i used again, but don't remember it saying anything about prep add-on.
Also tried factory reset yes but no luck.
- StephenBJun 30, 2021Guru - Experienced User
It'd be helpful to know what you actually did. The prep add-on just avoids the need to manually do a factory default after you do the install.
A factory default is definitely needed (whether automatically done by the prep add-on or manually). You could try it again.
What do you see when you boot up the Ultra diskless?
This hould be the guide i followed, so i did use the prep add-on:
https://blah.cloud/just-for-fun/upgrading-a-legacy-readynas-from-raidiator-4-2-x-to-6-2-x/
When i try to start without disk i get:
ERR: Firmware checksum error
And when i try to factory reset i get 2 errors:
ERR: could not create volume
ERR: registering data filesystem
I have also tried to make a USB recovery to see if that would help, but can't create it.
Tried on 2 different computers but the usbrecovery.exe gives me errors.
Not sure if the translation is correct " side by side configuration is incorrect"
