elliot_pl
Apr 05, 2012Aspirant
RNDU4000 disaster recovery?
Hi, I'm planning to buy Ultra4 for home use. I will definitely use XRaid. Of course - backup must be done frequently, but let's assume some sort of failure of ReadyNas itself after a warranty. Let'...
yoh-dah
Apr 05, 2012Guide
elliot_pl wrote: Hi,
I'm planning to buy Ultra4 for home use. I will definitely use XRaid. Of course - backup must be done frequently, but let's assume some sort of failure of ReadyNas itself after a warranty. Let's also assume that HDD's are fine. Is there a way to recover data from disks managed by XRaid? And I'm talking 3 or 4 disks in one volume.
Is it even possible to put drives to another (healthy) ReadyNas? What are the options?
Cheers,
Elliot
Yes, you can put the drives in another ReadyNAS as long as it's running the same architecture.
