chereszabor
Aug 12, 2019Aspirant
RNDU4000 will not boot
Hi Everyone, I am having issues booting my RNDU4000 after a few years of it sitting on the shelf (without power). The symptoms: After plugging power cable: short press powers on the unit, Fan ...
Aug 12, 2019Guru - Experienced User
chereszabor wrote:
Does anyone have any suggestions how I could resolve this?
About the only things you can replace are the power supply (PSU), the memory and the fans. It's clearly not the fans.
Opening the unit and reseating the memory is worth a try - it might have gotten loose during the storage.
If you have a spare ATX PSU, you can jury-rig it to power the NAS (with suitable extension cables). That would test out the PSU failure theory. Or just get a compatible replacement on speculation. Sandshark often gives useful advice on this.
