Tehbb
Oct 04, 2020Aspirant
RNP 6 front display interface?
I have been playing around with my RNP6 and I am wondering if there is a way to interface with the front display panel and make it display custom mesages. I have bee looking around in htop for a proc...
Tehbb
Jan 16, 2021Aspirant
can confirm that my lcd controller board is DEAD the micro gets abnormally hot when the board is plugged in
im considering using a similar display board or making one
I found this site
http://git.natisbad.org/NAS5/index.html
the site mentions that a parralell lcd display similar to this
https://www.winstar.com.tw/products/character-lcd-display-module/lcd-display-16x2.html
netger probererably used a custom version though
upon following the traces on my lcd module two of the connections connect straight to a ground plane and short together
so there are 8 connections
there is an led and ir sensor also on the board which would require more pins and also a 4 pin connector that isnt connected to the mainboard 3 of those pins are connected to traces
the minimum amount of pins required to make a parralell lcd function is 8 (which is in 4 bit mode)
I have one of these display modules and I am going to try to find the pinout for the connector
this is the pin layout of the connectors:
2 4 n/a 8 10 n/a 14 16
1 3 5 7 9 n/a 13 n/a
image attached with better pin diagram
below are voltages from the cable from the mainboard
WARNING these connections may be flipped im not sure
13.85 V between GND pin:8 VCC pin10 the pins also make continuity
using ground probe on pin 8 this is what voltage reading I got from the other pins
10.68 V pin 6 (the one that isnt populated)
13.82 V pin 4
10.30 V pin 2
15.57 V pin 9
22.73 V pin 7
00.00 V pin 5 this is when i got real suspicious of the connector being flipped
10.48 V pin 3
10.48 V pin 1
diddent check continuity between other pins
I flipped the cable connection from the mainboard and the display still wont work
the strange thing about this is that the display was working fine a week ago when I last checked
paranormal activity?
also im not sure if im being dumb but im pretty sure that the display doesent take sutch high voltages as measured
mainboard issue?
also attached is a partial reconstruction of the board
What I think the pins are
- maybe vcc?
- Unsure connected through smaller smd
- Unknown
- Unsure connected vcc smd
- Unknown
- Not populated
- Unknown
- most likely GND
- Unknown
- gnd loop connection or something?
- Not populated
- Not populated
- Unknown
- Unknown
- Not connected to anything
- Unknown
havent looked into it yet but this looks to be similar to the board from the earlier link
https://www.pololu.com/product/772
but the voltages would still be way off
maybe I have mainboard issue
if anyone else could check the voltages to the board it would be mutch apreciated
thats all I've got so far
Sandshark
Jan 17, 2021Sensei
I believe something is very wrong with either your NAS or the measurements you made. AFAIK, the display panel runs exclusively on 5V. I know it will come on and display "ReadyNAS" if there is nothing but 5V present in the NAS, but I have not taken any measurements of the voltages. I am not aware of any voltage above +12V anywhere in the NAS. There are certsainly no logic signals that should be above 5V. Have you, perhaps, mistaken the -12V bus for ground in your measurements? I'm not sure how you'd get the 10V measurements that way, though.
