robmaz
Jul 26, 2017Star
RR3312 with UPS/RFC1628 MIB
Hello, trying to get my ReadyNAS 3312 under UPS control. We are apparently expected
to somehow talk with Generex CS121 adapters (over the network) [1]. They are not in the
networkupstools suppoted list [2], but claim to support the RFC1628 MIB, for which there
apparently is some support, so this may be the option I would like to try. But how do I set
this in the admin web interface? I do no see a corresponding setting in the
System > Power > UPS dropdown. Many thanks in advance!
You don't see SNMP UPS in the UPS type pulldown?
But per the manual, this is only uses manufacturer specific MIBs (see page 195 here: http://www.downloads.netgear.com/files/GDC/READYNAS-100/READYNAS_OS_6_SM_EN.pdf ). Still one of the MIB options might be compatible.
Yes, thank you, I see these options, but "ietf" is not in there, although mentioned in the compatibility list
and the snmp-ups manpage [1]. But then the manpage says the driver will probe the ups anyway and try
to autodetect the correct MiB. So what is the difference between choosing different manufacturers anyway,
as long as they load the snmp-ups driver?
