dallis11
Apr 27, 2021Aspirant
RR4360X - Intermittent Error - "power supply no longer detected" error
I started seeing this error in the logs. I've seen it twice about 4 days apart. The power supply is showing as online however. Recommendations? 6.10.1v - ReadyNAS - Thanks
dallis11
May 14, 2021Aspirant
Ok - fair enough.. you just had said if you had 2 online you could hotswap one is all. Thanks for all the help- I have desktop 4 bay models at home too. the 60 bay models @ work.. have 3 are a new experience for me.
dallis11
May 18, 2021Aspirant
You were correct:
"The rr4360 supports up to four power supplies. Two are required. As long as two remain operating, the supplies are hot swappable." from the manual.
Do you know how to identify how the PSUs are numbered? I need to replace PSU3.
nothing in the docs about it. is the chassis numbered? Thanks so much!
