OskarB
Dec 23, 2015Aspirant
rsync path
I have readyNAS NV+ v2, running RAIDiator 5.3.11, located on the local network at 192.168.1.200. There is a share called "oskarsbag", with SMB and rsync protocols enabled. There is a NAS box user ca...
- Dec 23, 2015
I edited your post, and fixed the issue with the emoticon. An easy workaround is to bold the :
Dec 23, 2015Guru - Experienced User
Ordinary rsync uses port 873.
You need the volume name in the path. Normally that is "C" on a v2 - not sure if the "C" is upper or lower case, so maybe try them both.
rsync -ruv [email protected]:/C/oskarbag/dirxyz/ ~/dirback
- OskarBDec 23, 2015Aspirant
Thank you StephenB for your help.
With this and further experimentation, with Linux Mint on the desktop client, I found the following works for rsync-ing and mount-ing via desktop shell comamnds::
to rsync ("dry run"):
rsync -ruvn [email protected]::oskarbag/dirxyz/ ~/dirback
to mount (at "mpoint"):
sudo mount.cifs -o username=oskar,sec=ntlm,rw //192.168.1.200/oskarbag ~/mpoint
(mount.cifs will prompt for oskar's password on NAS. Mounting at local mountpoint is required to run Linux applications that can navigate only the local filesystem against the NAS-resident files)
thanks again,
Oskar
- StephenBDec 23, 2015Guru - Experienced User
