q3d
Jun 24, 2021Aspirant
Safely remove Apps from CLI?
Just some maintance - Is it possble to nuke any trace of previously installed apps using SSH?
I've uninstalled them from Frontview (ie there are no "installed apps" listed), however they still show with issues in the logs.
Some of these were prior installed - long since removed on older OS's:
| Jun 25, 2021 10:59:16 AM | System: Found app [smbplus] with bad configuration. Disabling its configuration page. | |
| Jun 25, 2021 10:59:15 AM | System: Found app [shellinabox] with bad configuration. Disabling its configuration page. | |
| Jun 25, 2021 10:59:15 AM | System: Found app [phpr6] with bad configuration. Disabling its configuration page. | |
| Jun 25, 2021 10:59:14 AM | System: Found app [shellinabox] with bad configuration. Disabling its configuration page. | |
| Jun 25, 2021 10:59:14 AM | System: Found app [phpr6] with bad configuration. Disabling its configuration page. | |
| Jun 25, 2021 10:59:09 AM | System: Found app [smbplus] with bad configuration. Disabling its configuration page. | |
| Jun 25, 2021 10:59:08 AM | System: Found app [shellinabox] with bad configuration. Disabling its configuration page. | |
| Jun 25, 2021 10:59:08 AM | System: Found app [phpr6] with bad configuration. Disabling its configuration page. | |
| Jun 25, 2021 10:59:07 AM | System: Found app [shellinabox] with bad configuration. Disabling its configuration page |
Take a look at /apps, and see what's in the folders for those apps.
1 Reply
