KillerBob
Mar 07, 2012Aspirant
Samsung Spinpoint F1 errors
Hi, I have a Pro Pioneer, with 6 Samsung Spinpoint F1s disks installed. They have been in there for a few years, and I have a disk with a few SMART errors; Raw Read Error Rate - 3 Read Sector E...
Mar 12, 2012Guru - Experienced User
No clue about OSX diags. As long as the diag is non-destructive it should be safe. You do need to shut down the pro before you remove the disk, and leave it off until the testing is complete.
KillerBob wrote: Hi,
If I wanted to check the HD specifically, it being a Samsung F1 (HD103UJ), what Disk testing utility should I use? I can't locate a specific one for Samsung HDs, and I don't of any good generic ones for OSX. And, should I for instance use Tech Tool, is it safe to take out the specific HD from the Pro, test it, and reinsert? I.e. do I stand the chance of f...... something up on the HD?
Bo
