KillerBob
Mar 07, 2012Aspirant
Samsung Spinpoint F1 errors
Hi, I have a Pro Pioneer, with 6 Samsung Spinpoint F1s disks installed. They have been in there for a few years, and I have a disk with a few SMART errors; Raw Read Error Rate - 3 Read Sector E...
gibxxi
Mar 18, 2012Guide
The best tool for HDD diagnosis is and always has been SpinRite 6 from GRC. However, the program requires a bootdisk, and it's showing it's age. It was never designed to work with modern RAID controllers in PC's (whether using the RAID features or not) and several PC's I've attempted to use it on have caused it to crash after scanning for a short period. Probable BIOS incompatibility. HDDScan is a good tool for identifying potential problems and weak sectors on a HDD, and is free. A good substitute if you can't run a DOS-based tool.
http://hddscan.com/
http://hddscan.com/
