Wyomoose
Sep 29, 2021Aspirant
Scheduling NetGear NAS OS 6 Audit Logs to copy to a separate file share Sending
Not sure exactly what model we have but we are using ReadyNAS 6. Posted about 19 months ago or so about getting NAS archive logs into Splunk. Te suggestion was to connect to the NAS and use CLI to du...
- Sep 29, 2021
Thks Sandshark we probably will then.
Sandshark
Sep 29, 2021Sensei
Simply enabling SSH does not void the warranty. However, if SSH is enabled and Netgear determines that a problem you are asking for warranty assistance with was due to somehting you did via SSH, support may be denied.
- WyomooseSep 29, 2021Aspirant
