claynz
Apr 14, 2022Guide
Scrub Stuck on 56.67%
My NAS unit has been stuck on Scrub at 56.67% for a few days now, how do I fix this?
claynz
Apr 14, 2022Guide
How do I query the status with ssh, I think it's enabled.
Apr 15, 2022Guru - Experienced User
Log in as root, using the NAS admin password.
There are actually two scrubs going on in parallel - btrfs and RAID.
To check the RAID status you can enter
cat /proc/mdstat
There should be a line in there that shows resync status (and estimated finish time).
To check the BTRFS scrub status you can enter
btrfs scrub status /data
(assuming XRAID here - use your actual volume name if you are using FlexRAID).
If you have disk spindown enabled, it might go faster if you disable it for a while. Another thing you might consider is downloading the log zip file from the admin ui, and look for any btrfs or disk-related errors.
