choman's avatar
choman
Stuck scrubbing
My readynas seems to be stuck in scrubbing mode.   I cannot access shares, access the the UI, nor access via ssh.
Is this safe to rebooot?
Need assistance please
  • I can take a screenshot of the front door, but IMHO it doesn't seem to help
  • StephenB's avatar
    What model NAS?
    What firmware is it running?
    What status does RAIDar give you?
    • https://kb.netgear.com/20684/ReadyNAS-Downloads#raidar
    Try downloading the log zip from RAIDar (might not work but worth a try).
    Does the NAS respond to ping?
  • "Stuck" for how long?  Do you run scrubs on a schedule?  If so, what is the typical duration?  A scrub can take a very long time, especially if you have SMR drives.  On units with a lesser CPU, it can "take over", essentially locking you out of the GUI and SMB.  But SSH is typically still able to connect, so that's different for you.
    I had an issue on one of my NAS that seemed to lock up the scrub.  But it was a rack-mount unit with a powerful enough CPU that it was still accessible via SMB and the GUI.  What I found was doing it was a very large file that was fragmented.
    A "scrub" on a ReadyNAS actually does a BTRFS scrub and an MDADM re-sync.  While both are usually safe to interrupt with a power cycle, it's not recommended.  And with two ongoing things that could go wrong, that doubles the chance of something bad happening.
ProSupport for Business
