chopin70
Jan 05, 2016Virtuoso
Scrub/Defrag/Snapshots with Seagate Archive 8TB - ST8000AS0002
Hi, I am thinking at putting a pare of these disks as XRAID (data redundancy) in my legacy Ultra 2 unit with latest 6.4.1 firmware. I understand the limitations. However, I does own one in my de...
Jan 05, 2016Guru - Experienced User
I don't recommend them for NAS use (and Seagate specifically warns against it).
If you search this forum, you'll find that these drives are controversial. However, even the proponents have had some problems with them in the ReadyNAS.
At least some of these problems seem to have been fixed in 6.4.1 - perhaps some of the users of these drives will comment on their current experience (and give some real data on volume maintenance times).
If you don't get a response, try PMing powellandy1
chopin70
Thanks, I will wait a little as you suggested
I also read about the issues, fixed in 6.4.1 from the feedback
This disk is in fact very tempting for the price /Gb
For archive/backup purpose, in my desktop, it is just an amazing disk with great performances.
I have one Archibe 8Tb disk in my desktop PC since 6 months now. I use it as a backup that is mirrored to the NAS each 6h on a schedule. Performance wise, the NAS with standard HDDs in it has much lower performances than my desktop with the archive HDD. Be it read or sustained write, the Ultra 2 NAS with 7500 rpm disks is far behind. I took time to test it. If we stay to its dedicated use, it just beats any current disk price per performance wise.
So I don't think I will be disappointed with its performances in a RAID 1 setup used the way I do: backups + streaming
The main concern is really about the maintenance tasks, mainly routine snapshots and the deadly scrub.
- chopin70Jan 05, 2016Virtuoso
I found this topic on FreeNAS
https://forums.freenas.org/index.php?threads/seagate-8tb-archive-drive-in-freenas.27740/page-3
Scrub speed seems all but an issue
So I am really tempted
- mdgm-ntgrJan 05, 2016NETGEAR Employee Retired
Well how do the specs of your PC compare with that of the Ultra 2? Also, what model disks are you using in the Ultra 2?
Certainly when looking at current generation disks, the Archive disks are pretty slow.Well I would probably schedule 3-4 scrubs a year max.
Desktop is an i5 clocked at 3.4 GHz with 32 Gb of RAM, so yes, it is faster than my Ultra 2 NAS.
The disks in the NAS are Seagate NAS HDD 4TB - ST4000VN000 (2x): 64Mb cache and 5900 rpm
The write speed of 2 to 16Gb files is very poor from desktop to the NAS (75 MB /sec), compared from desktop disk 1 to desktop Archive HDD (150 MB /s). NAS is using a full 1Gb LAN connection
Scrubs are scheduled every 3 months
- StephenBJan 06, 2016Guru - Experienced User
Not sure if this is useful to you: http://www.storagereview.com/seagate_archive_hdd_review_8tb
They put two drives in a synology DS1815+ and measured read/write and rebuild times for a RAID-1 array.
Building the array took ~57 hours (~3x longer than a PMR drive). Large backups averaged about 30 MB/s. Small incremental backups ran about the same speed as a PMR disk.
I think if I were doing this I'd use jbod, and set up incremental backup jobs to update the second volume from the first. That reduces the stress of the long resync times, and gives you the option of switching to the second volume when the first had poor performance. If you go that route, stagger the maintenance schedules.
