Sly_Raskal
Oct 31, 2016Guide
Seagate 6TB Ironwolf (ST6000VN0041) Incompatible with ReadyNAS disk trays
I took a risk and purchased 4 x 6TB Seagate Ironwolf drives, Model #ST6000VN0041 and unfortunately the mounting holes for the disks are not matched with the trays that come with the ReadyNAS 314. ...
kohdee
Feb 08, 2017Administrator
The plastic insert on tool-less trays comes out, so you didn't have to clip the plastic tray to fit the drive in, widthwise.
- baeckergFeb 08, 2017Aspirant
doesn't that defeat the purpose of "toolless"? And it is not easy to remove the frame.
- mdgm-ntgrFeb 09, 2017NETGEAR Employee Retired
Well it is a workaround so that you can use these disks with the tray and the screws you already have.
- baeckergFeb 09, 2017Aspirant
Will Netgear provide an updated tray in the future?
- StephenBFeb 09, 2017Guru - Experienced User
It isn't difficult to remove the inserts, and it's not something you'd touch very often. You'd also need to remove them to use a 2.5" SSD.
Vote for the idea here (click on the uparrow), and add a comment that you'd like to see the updated trays available for purchase.
